소개
Complete replacement of the outer case requires complete dissassembly of the camera. This is a good time to replace other components if needed.
필요한 것
Use a prying motion and a plastic opening tool to pry the side panel up.
Pull the panel down there are 2 clips in the midtle be carefull not to brake them
It is not clips but "hook" so to the mouvement should be at opposite direction on flash
I inserted an opening pick under the lower part of the panel (where it was loosest; at the left of the photo) and then inserted a jimmy along one side (at the top of the photo). Then I pushed the panel down from the top (at the right in the photo) and it popped off.
Orient the device so that the LCD is facing you ("back view").
Using the plastic opening tool to lift the black retaining clip up to disengage the ribbon cable. Then gently pull the ribbon cable to remove.
when screen cable is plug, you can test before reassemble the device.
Help this is an urgent need please !!! I am stuck at step 12 : lifting the black retaining clip up just pops it out like a pop corn (tried several times) and then nothing moves :-(
larosedu92 - 답글
No need to unplug the LCD, to take the lens
Il est inutile de débrancher l’écran LCD pour retirer l’objectif
Remove the black M1.4 X 3.5 Phillips head screw in upper right corner of the device.
Service manual for reference: Click to go to the service manual.
Lift the lens block from the case.
Exactly with this very helpful description I have successfully changed my noisy lense system
thans a lot D. A. Waldvogel
Discharge the capacitor by connecting the resistor jig between the highlighted squares.
Remove the black M1.4 X 3.5 Phillips head screw in upper right corner of device.
The connections (red squares) have small black retaining clips. Using a plastic opening tool, lift upward towards the cable to unlock.
After detaching retaining clips, gently lift to disconnect the ribbon cables.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
can i follow the same instruction for SONY DSC HX 10V .as both looks identical . when i shake my camera sound comes as if some parts are loosen but when i switched on my camera and the lens comes out that sound goes off . should i care for it or not ?
Thank you! Useful instructions.
Step 5 - perhaps a little more accurate step would be to lift up the bottom of the panel and then slide the panel downward. (reinstall in reverse direction).
I am having trouble orienting the control wheel - I tried to seat the middle button so it clicks and then set down the wheel on top but that does not seem to work after putting the back cover on. I’ve reopened and tried many times. Any suggestions on how to orient or reinstall the control wheel.
