주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement
필요한 것
    1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Make sure the camera is powered off
      • Turn the camera upside down. This is a view of the bottom of the camera.
      댓글 쓰기
    2. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 2 단계, 이미지 1개 중 1개
      • Push battery cover away from the camera.
      댓글 쓰기
    3. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 3 단계, 이미지 1개 중 1개
      • Push the blue tab that secures the battery. The battery will then spring out.
      댓글 쓰기
    4. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the battery.
      댓글 쓰기
    1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
      • Make sure to remove the battery before disassembly to prevent electrocution.
      • Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
      • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
      • Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
      댓글 쓰기
    2. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 6 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 6 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, separate the plastic camera housing.
      댓글 쓰기
    3. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 7 단계, 이미지 1개 중 1개
      • Disconnect the ribbon wire attaching the screen to the camera.
      댓글 쓰기
    4. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 8 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 8 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 8 단계, 이미지 3개 중 3개
      • Carefully remove the 7 ribbon wires connected to the mother board.
      • Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
      • Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
      • Lift up on the speaker mounting bracket to remove it.
      댓글 쓰기
    5. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 9 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 9 단계, 이미지 2개 중 2개
      • Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
      • Once the Motherboard is removed the replacement can be installed.
      댓글 쓰기
    1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, HDMI/USB port: 10 단계, 이미지 1개 중 1개
      • Remove the 3 (4 cm) Phillips head screws securing a mounting bracket over the HDMI/USB Port.
      댓글 쓰기
    2. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 11 단계, 이미지 1개 중 1개
      • Lift up on the mounting bracket to remove the HDMI/USB Port from the camera.
      댓글 쓰기
    3. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 12 단계, 이미지 1개 중 1개
      • Once the HDMI/USB Port is removed the replacement can be installed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Elizabeth Surface
회원 가입일: 08/26/15
1,477 평판
안내서 9개를 작성함
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015 회원
USFT-MEIER-F15S4G6
4 회원들
안내서 108개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 50
전체 시간: 2,156
