소개
If the Sony Cyber-shot DSC-HX300 is failing to power, while it has a full battery and the LCD screen works, then it is possible that the motherboard has gone out and needs to be replaced.
필요한 것
Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
댓글 3개
During my vacation two capicators on the motherboard failed and 'exploded'.
I've ordered the motherboard and replaced it exactly as described here. Thanks for the explanation!
But since I've replaced it, I have autofocus problems, the camera isn't capable to focus, especially in wide zoom.
Is this something that needs to be calibrated or something?
That ist what i need to know too. Where can i order a Motherboard?
