주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-HX300 View Finder Replacement
필요한 것
  1. Sony Cyber-shot DSC-HX300 View Finder Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 View Finder Replacement: 2 단계, 이미지 1/1
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 View Finder Replacement: 3 단계, 이미지 1/1
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 View Finder Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-HX300 View Finder Replacement: 4 단계, 이미지 2/2
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: 5 단계, 이미지 1/3 Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: 5 단계, 이미지 2/3 Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: 5 단계, 이미지 3/3
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Philips head screws holding the plastic camera housing together. They are located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down and remove the remaining 3 (4 cm) Phillips head screws holding the plastic housing together.
  6. Sony Cyber-shot DSC-HX300 View Finder Replacement: 6 단계, 이미지 1/2 Sony Cyber-shot DSC-HX300 View Finder Replacement: 6 단계, 이미지 2/2
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 View Finder Replacement: 7 단계, 이미지 1/1
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 View Finder Replacement: 8 단계, 이미지 1/2 Sony Cyber-shot DSC-HX300 View Finder Replacement: 8 단계, 이미지 2/2
    • Remove the 1 (2 cm) Phillips head screw
    • Remove the 2 (5 cm) Phillips head screws that mount the View Finder to the camera.
    • Carefully disconnect the ribbon wire that connects the View Finder to the Motherboard.
  9. Sony Cyber-shot DSC-HX300 View Finder Replacement: 9 단계, 이미지 1/2 Sony Cyber-shot DSC-HX300 View Finder Replacement: 9 단계, 이미지 2/2
    • Gently pull the plastic View Finder off of the metal mounting bracket.
  10. Sony Cyber-shot DSC-HX300 View Finder Replacement: 10 단계, 이미지 1/1
    • The replacement View Finder can now be installed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elizabeth Surface
회원 가입일: 08/26/15
1,465 평판
안내서 9개 작성하였습니다
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015 회원
USFT-MEIER-F15S4G6
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 1,204
