주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-HX80 LCD Screen Replacement
필요한 것
  1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
    • Before disassembling any part of the camera, turn off the power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
  2. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Open the compartment located at the bottom of the camera. Slide the LOCK/OPEN switch to the OPEN side. Locate the small blue tab on the side. Pull it in direction away from battery. Remove the battery and set it aside.
  3. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Flip LCD screen upwards.
    • Use the PH000 Phillips head screwdriver to remove the two 0.3 mm Phillips black screws located on the sides of the LCD screen. Place screws on magnetic mat or plastic bag.
  4. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Use the PH000 Phillips head screwdriver to remove the two additional 0.3 mm black Phillips screws located on the top edge of the LCD screen. Place screws on magnetic mat or plastic bag.
  5. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 5 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 5 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Use a nylon spudger to gently remove the damaged LCD screen off the camera.
    • Replace LCD screen with new one.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Gordon Jones
회원 가입일: 10/02/18
1,081 평판
안내서 5개를 작성함
Sam Houston State, Team S11-G1, Blackburne Fall 2018 Sam Houston State, Team S11-G1, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S11G1
4 회원들
안내서 12개를 작성함
7가이드 댓글
You should note that there is a small rectangular magnet (perhaps 8mm long and 2mm across) that has to be placed at the top of the LCD directly under the flash switch. Otherwise the LCD image will be upside down.
Dale Bjerning - 답글
Hello could you show a picture of where exactly under the flash has to be the magnetite tangle. Thanks.
Wolfina -
Anyone know where I can find the cable from the screen to the camera?
Thorusofer Dragon Knight - 답글
same question here! i repalced the lcd thinking that was the problem but the lcd is still black. the viewfinder works fine so i think i need to replace the cable that goes from the camera to the screen. any info?
Facundo V -
where can i find the screen other then threw sony
ninjadawn25 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 62
전체 시간: 4,537
