소개
In the event of a damaged LCD screen, the only option may be for you to replace it. The following guide will take you step by step through the process.
부품
지정된 부품이 없습니다.
Before disassembling any part of the camera, turn off the power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
You should note that there is a small rectangular magnet (perhaps 8mm long and 2mm across) that has to be placed at the top of the LCD directly under the flash switch. Otherwise the LCD image will be upside down.
Anyone know where I can find the cable from the screen to the camera?
where can i find the screen other then threw sony
