주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-HX80 Shutter Button Replacement
필요한 것
  1. Sony Cyber-shot DSC-HX80 Shutter Button Replacement, Shutter Button: 1 단계, 이미지 1개 중 1개
    • Before disassembling any part of the camera, turn off the power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
  2. Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 2 단계, 이미지 1개 중 1개
    • Open the compartment located at the bottom of the camera. Slide the LOCK/OPEN switch to the OPEN side. Locate the small blue tab on the side. Pull it in the direction away from battery. Remove the battery and set it aside.
  3. Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 3 단계, 이미지 2개 중 2개
    • Use the PH000 head screwdriver to take screws out. Begin unscrewing from the bottom of camera.
    • At the end of this step there will be a total of five black 0.4 mm Phillips screws. Place them on a magnetic mat or a plastic bag.
  4. Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 4 단계, 이미지 1개 중 1개
    • Leave the screws holding the LCD screen in place!
  5. Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 5 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 5 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 5 단계, 이미지 3개 중 3개
    • Keep working alongside each side of the camera until all screws are addressed.
    • In addition to the five screws from the bottom, a total of three more 0.4 mm black Phillips screws are located as indicated in the photo. Place them on the magnetic mat or plastic bag.
  6. Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 6 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 6 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 6 단계, 이미지 3개 중 3개
    • Flip the LCD screen upwards. Use the PH000 Phillips head screwdriver to remove screws located under the LCD screen.
    • For this step there will be an additional three 0.3 mm black Phillips screws. Place them on magnetic mat or plastic bag.
  7. Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 7 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 7 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 7 단계, 이미지 3개 중 3개
    • Use the plastic opening tools included in the iFixit tool kit first. If the shell/parts do not detach from each other, use metal spudgers as a last resort to loosen/separate the plastic shell of the camera. Keep in mind that there may be more screws holding parts together. Work delicately and separate sides evenly.
  8. Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 8 단계, 이미지 1개 중 1개
    • After loosening the plastic edges of the camera, gently pull the LCD screen upwards.
  9. Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 9 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 9 단계, 이미지 2개 중 2개
    • Locate the two 0.3 mm silver screws that hold the face of the screen in place. Use the PH000 Phillips head screwdriver to remove screws.
    • Place the two 0.3 mm screws on magnetic mat or plastic bag.
  10. Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 10 단계, 이미지 1개 중 1개
    • Use metal spudger to detach the face of the screen off the rest of the camera. Be extremely careful as there is a thin golden film/plastic ribbon holding the face of the screen to the rest of the camera.
  11. Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 11 단계, 이미지 1개 중 1개
    • After separating the face of the screen, look for the screws located on the circuit board. These screws are what allow the thin golden film/plastic ribbon to connect the top part to the rest of the camera. Remove the 0.4 mm circuit board screws by using the PH000 Phillips head screwdriver.
    • Place the two screws on magnetic mat or plastic bag.
  12. Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 12 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 12 단계, 이미지 2개 중 2개
    • Gently pull the circuit board off the top piece. The top piece, which has the shutter button attached, will then be detached from the rest of the camera.
  13. Sony Cyber-shot DSC-HX80 Shutter Button Replacement: 13 단계, 이미지 1개 중 1개
    • Replace the non-functioning top piece of the camera with a new one.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Gordon Jones
회원 가입일: 10/02/18
1,081 평판
안내서 5개를 작성함
Sam Houston State, Team S11-G1, Blackburne Fall 2018 Sam Houston State, Team S11-G1, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S11G1
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 21
전체 시간: 2,225
