주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-HX90V Button Board Replacement
필요한 것
  1. Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: 1 단계, 이미지 1/3 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: 1 단계, 이미지 2/3 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: 1 단계, 이미지 3/3
    • Remove the marked screw with a Phillips #000 screwdriver.
    • Remove the marked black M1.4 X 3.5 Phillips head screws
    • Use the spudger to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Button Board  Replacement: 2 단계, 이미지 1/3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: 2 단계, 이미지 2/3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: 2 단계, 이미지 3/3
    • After removing the marked black M1.4 X 3.5 Phillips head screws with the Phillips #000 screwdriver on the side panel, using the spudger where the red arrow marks, insert and gently remove the side panel from the device.
    • From either corner of the button board gently use hands to remove the button board.
  3. Sony Cyber-shot DSC-HX90V Button Board  Replacement: 3 단계, 이미지 1/3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: 3 단계, 이미지 2/3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: 3 단계, 이미지 3/3
    • After the outer black panel case of button is removed, gently disconnect the control board data cable to the motherboard utilizing the tweezers gently where the red arrow marks.
    • Ribbon wires can easily be damaged.
결론
Marin Rusinov
회원 가입일: 02/02/17
853 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 25
전체 시간: 2,000
