주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-HX90V Lens Replacement
필요한 것
  1. Sony Cyber-shot DSC-HX90V Lens Replacement, Button board: 1 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX90V Lens Replacement, Button board: 1 단계, 이미지 2개 중 2개
    • Place the device so bottom of the camera is facing up .
    • Remove the five marked screws with a Phillips #000 screwdriver.
    • Insert the spudger where arrow marks to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Lens Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the marked screw on the side of the camera with a Phillips #000 screwdriver.
  3. Sony Cyber-shot DSC-HX90V Lens Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the marked screw with a Phillips #000 screwdriver.
  4. Sony Cyber-shot DSC-HX90V Lens Replacement: 4 단계, 이미지 1개 중 1개
    • Orient the device so the lens is facing down.
    • Remove the two black M1.4 X 3.5 Phillips head screws using Phillips #000 screwdriver.
  5. Sony Cyber-shot DSC-HX90V Lens Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the black M1.4 X 3.5 Phillips head screw.
  6. Sony Cyber-shot DSC-HX90V Lens Replacement, Side cover: 6 단계, 이미지 1개 중 1개
    • Use the plastic opening tool with a prying motion to remove the side cover of the camera.
    • The cover should come off easily but you might hear light snapping or popping.
  7. Sony Cyber-shot DSC-HX90V Lens Replacement, LCD: 7 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX90V Lens Replacement, LCD: 7 단계, 이미지 2개 중 2개
    • Remove the small screw under the multi/USB cover.
    • Use the plastic opening tool to remove the button board.
  8. Sony Cyber-shot DSC-HX90V Lens Replacement: 8 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX90V Lens Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the control board data cable with care. Permanent damage may occur to the control board if tools are used to disconnect the data cable. Use your fingers only.
    • Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
  9. Sony Cyber-shot DSC-HX90V Lens Replacement: 9 단계, 이미지 1개 중 1개
    • LCD screen is very fragile. Handle with care. Do not use tools to remove the screen.
    • Lift the metal plate and LCD screen simultaneously until it is perpendicular to the camera.
  10. Sony Cyber-shot DSC-HX90V Lens Replacement, Motherboard: 10 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX90V Lens Replacement, Motherboard: 10 단계, 이미지 2개 중 2개
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing.
  11. Sony Cyber-shot DSC-HX90V Lens Replacement: 11 단계, 이미지 1개 중 1개
    • Make sure all ribbon cables are unplugged and remove the motherboard.
    • Ribbon wires can be easily damaged.
  12. Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: 12 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: 12 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: 12 단계, 이미지 3개 중 3개
    • Press on the lens with your finger.
    • Gently pull the lens container out of the camera.
    • Make sure all ribbon wires are unplugged.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Marin Rusinov
회원 가입일: 02/02/17
853 평판
안내서 5개를 작성함
5가이드 댓글
Aside from a few missed screws, very nicely done. And I suspect that if one didn’t realize the need to remove those screws, sh/e probably shouldn’t be attempting the job in the first place. :) (I noted the comments after completing lens removal.)
Leon - 답글
Can you comment where/specifically the missing screws that were not listed can be found? Any other guides out there that are more comprehensive?
Eric C -
Under multi cover
Dufour - 답글
First at step 7
Dufour -
At step 8 remove two 2mm screws both lower sides of LCD
Dufour - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 26
지난 30일: 111
전체 시간: 13,768
