주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-HX90V Motherboard Replacement
필요한 것
  1. Sony Cyber-shot DSC-HX90V Motherboard Replacement, Button board: 1 단계, 이미지 1개 중 1개
    • Place the device so bottom of the camera is facing up .
    • Remove the five black M1.4 X 3.5 Phillips head screws with a Phillips #000 screwdriver.
  2. Sony Cyber-shot DSC-HX90V Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the marked black M1.4 X 3.5 Phillips head screws on the side of the camera with a Phillips #000 screwdriver.
  3. Sony Cyber-shot DSC-HX90V Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the marked screw with a Phillips #000 screwdriver.
  4. Sony Cyber-shot DSC-HX90V Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX90V Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to remove the button board.
  5. Sony Cyber-shot DSC-HX90V Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX90V Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the control board data cable with care. Permanent damage may occur to the control board if tools are used to disconnect the data cable. Use your fingers only.
    • Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
  6. Sony Cyber-shot DSC-HX90V Motherboard Replacement, Side cover: 6 단계, 이미지 1개 중 1개
    • Use the plastic opening tool with a prying motion to remove the side cover of the camera.
    • The cover should come off easily but you might hear light snapping or popping.
  7. Sony Cyber-shot DSC-HX90V Motherboard Replacement, LCD: 7 단계, 이미지 1개 중 1개
    • Orient the device so the lens is facing down.
    • Remove the two black M1.4 X 3.5 Phillips head screws using Phillips #000 screwdriver.
  8. Sony Cyber-shot DSC-HX90V Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the black M1.4 X 3.5 Phillips head screw.
  9. Sony Cyber-shot DSC-HX90V Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX90V Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • LCD screen is very fragile. Handle with care. Do not use tools to remove the screen.
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing.
  10. Sony Cyber-shot DSC-HX90V Motherboard Replacement, Motherboard: 10 단계, 이미지 1개 중 1개
    • Make sure all ribbon cables are unplugged and remove the motherboard.
    • Ribbon wires can be easily damaged.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Marin Rusinov
회원 가입일: 02/02/17
853 평판
안내서 5개를 작성함
댓글 2개
super Anleitung, trotz aller Vorsicht ist ein Flachbandkabel kaputt gegangen, und zwar das 2 adrige zu Sucher. Wie kann man Flachbandkabel reparieren oder ersetzen?
LG
Michael
Michael Bühnen - 답글
Hello!
Nice help to open the camera for fixing viewfinder problems: when not switching on, even when FINDER/MONITOR mode on FINDER, there might be a bad contact in the visor connector. It is a snap lock micro connector, open the lock, then carefully remove clean and replace ribbon cable:this may clear the trouble.
But attention: At least on HX9O without V ext. there are some more screws ;-) and niceties
- one in step 3, under the MULTI connector cap
- 3 on different places to remove LCD screen
Also, there is also an antenna , connected to the LCD assembly and lightly glued on the side
Frantz Bernhard - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 42
전체 시간: 3,516
