주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-P100 Battery Replacement
필요한 것
  1. Sony Cyber-shot DSC-P100 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Pull the battery cover in the direction of the arrow.
  2. Sony Cyber-shot DSC-P100 Battery Replacement: 2 단계, 이미지 1/1
    • Allow the latch to be released.
  3. Sony Cyber-shot DSC-P100 Battery Replacement: 3 단계, 이미지 1/1
    • Push the battery latch away from the battery until the battery is released. Then remove battery.
  4. Sony Cyber-shot DSC-P100 Battery Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-P100 Battery Replacement: 4 단계, 이미지 2/2
    • Insert battery with the arrows directing into the camera.
    • It is important to put the battery in the camera in the correct direction in order for the camera to function properly.
결론
To reassemble your device, follow these instructions in reverse order with replacement battery.
다른 한 분이 해당 안내서를 완성하였습니다.
Katie McCraw
회원 가입일: 03/09/12
191 평판
안내서 7개 작성하였습니다
Clemson, Team 1-5, Benson Spring 2012 Clemson, Team 1-5, Benson Spring 2012 회원
CLEM-BENSON-S12S1G5
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 15
전체 시간: 2,886
