주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-P100 Camera Lens Replacement
필요한 것
  1. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: 1 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: 1 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: 1 단계, 이미지 3개 중 3개
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Camera Lens Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Lens Replacement: 3 단계, 이미지 1개 중 1개
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Lens Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-P100 Camera Lens Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: 5 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: 5 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: 5 단계, 이미지 3개 중 3개
    • Remove the four screws from the casing.
  6. Sony Cyber-shot DSC-P100 Camera Lens Replacement: 6 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-P100 Camera Lens Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully pull the back casing away from the camera.
  7. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: 7 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: 7 단계, 이미지 2개 중 2개
    • Remove the two screws on the back side of the camera surrounding the LCD screen.
  8. Sony Cyber-shot DSC-P100 Camera Lens Replacement: 8 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-P100 Camera Lens Replacement: 8 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-P100 Camera Lens Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the two ribbon traces found on the left side of the lens on the front of camera holding the lens in place.
    • Carefully pull the lens away front the camera until it is released.
  9. Sony Cyber-shot DSC-P100 Camera Lens Replacement: 9 단계, 이미지 1개 중 1개
    • The lens is now successfully removed from the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Katie McCraw
회원 가입일: 03/09/12
191 평판
안내서 7개를 작성함
Clemson, Team 1-5, Benson Spring 2012 Clemson, Team 1-5, Benson Spring 2012 회원
CLEM-BENSON-S12S1G5
4 회원들
안내서 14개를 작성함
댓글 한 개
Is there a way to disassemble the lens to correct the alignment. My daughter dropped it and I think the mechanism has been misaligned.
Macjune Tolentino - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 16
전체 시간: 2,795
