이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Open the battery compartment and remove the batteries.
Remove all of the visible screws on the outside of the case.
Open the memory card compartment.
Remove the screw next to the memory card slot.
Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
Remove all six screws on the front side of the motherboard circled in the picture.
Pull the motherboard from the rest of the housing.
Detach the ribbon cables shown.
Remove the flash unit from the motherboard.
Discharge the yellow capacitor attached to the flash unit by shorting the leads with a screw driver.
