소개
The LCD should be checked if the screen is blank or broken.
  1. Open the battery compartment and remove the batteries.
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Open the memory card compartment.
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Pull apart the front and back cover pieces carefully.
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Open the case as shown.
    • Open the case as shown.
  6. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  7. Unclip the clip holding the ribbon cable in.
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  8. Pull the ribbon cable out.
    • Pull the ribbon cable out.
  9. Unclip the ribbon cable shown the in picture.
    • Unclip the ribbon cable shown the in picture.
    • Some ribbon cables do not have a clip holding them in.
  10. Pull the ribbon cable out.
  11. Remove 7 Screws to remove plate and expose LCD screen.
    • Remove 7 Screws to remove plate and expose LCD screen.
  12. Remove LCD plate to expose LCD components and ribbon cables
    • Remove LCD plate to expose LCD components and ribbon cables
  13. Check connection of LCD to cables
    • Check connection of LCD to cables
    • If cables are intact, disconnect cables and replace LCD with new part
  14. Repeat steps in reverse order to reassemble the camera
    • Repeat steps in reverse order to reassemble the camera
결론
Mark
회원 가입일: 2011년 01월 11일
13 평판
안내서 1개 작성함
Cal Poly, Team 3-43, Regan Winter 2011 Cal Poly, Team 3-43, Regan Winter 2011 회원
CPSU-REGAN-W11S3G43
4 회원들
안내서 10개 작성하였습니다
I don’t know the cause of my camera not turning on.
Smgmc64 Productions - 답글
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 2,282
