이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Open the battery compartment and remove the batteries.
Remove all of the visible screws on the outside of the case.
Open the memory card compartment.
Remove the screw next to the memory card slot.
Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
Detach the ribbon cables and unplug the cable leading to the back of the motherboard.
Remove the screw indicated in the picture to detach the lens and the viewfinder from the other hardware.
Remove the three screws shown to separate the lens from the viewfinder.
Purchase a new viewfinder.
Repeat the previous steps in reverse order to rebuild.
다른 한 분이 해당 안내서를 완성하였습니다.
