주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-P52 Motherboard Replacement
필요한 것
  1. Sony Cyber-shot DSC-P52 Motherboard Replacement, Outer Case: 1 단계, 이미지 1/1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 Motherboard Replacement: 2 단계, 이미지 1/1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 Motherboard Replacement: 3 단계, 이미지 1/1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 Motherboard Replacement: 4 단계, 이미지 1/1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 Motherboard Replacement: 5 단계, 이미지 1/1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 Motherboard Replacement: 6 단계, 이미지 1/1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 Motherboard Replacement: 7 단계, 이미지 1/1
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 Motherboard Replacement, Motherboard Assembly: 8 단계, 이미지 1/1
    • Remove all six screws on the front side of the motherboard circled in the picture.
    • Pull the motherboard from the rest of the housing.
    • It will still be connected to the flash unit.
  9. Sony Cyber-shot DSC-P52 Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the cable on the back side of the motherboard.
  10. Sony Cyber-shot DSC-P52 Motherboard Replacement: 10 단계, 이미지 1/1
    • Detach the ribbon cables shown.
    • Careful! Touching the leads of the large yellow capacitor can result in a painful shock.
    • Remove the flash unit from the motherboard.
  11. Sony Cyber-shot DSC-P52 Motherboard Replacement, Motherboard: 11 단계, 이미지 1/1
    • The motherboard is now free, and ready to be replaced by a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Trevor
회원 가입일: 01/20/11
295 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-43, Regan Winter 2011 Cal Poly, Team 3-43, Regan Winter 2011 회원
CPSU-REGAN-W11S3G43
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 1,175
