주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-P9 LCD Replacement
필요한 것
  1. Sony Cyber-shot DSC-P9 LCD Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 LCD Replacement: 2 단계, 이미지 1/1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 LCD Replacement: 3 단계, 이미지 1/2 Sony Cyber-shot DSC-P9 LCD Replacement: 3 단계, 이미지 2/2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 LCD Replacement, LCD: 4 단계, 이미지 1/1
    • Unscrew the four 3.0mm Phillips #000 screws holding the back case onto the camera; there are two screws on top and two on the bottom.
  5. Sony Cyber-shot DSC-P9 LCD Replacement: 5 단계, 이미지 1/2 Sony Cyber-shot DSC-P9 LCD Replacement: 5 단계, 이미지 2/2
    • Pull the back case gently away from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 LCD Replacement: 6 단계, 이미지 1/1
    • Remove the two 3.0mm Phillips #000 screws holding the display to the metal backing.
  7. Sony Cyber-shot DSC-P9 LCD Replacement: 7 단계, 이미지 1/2 Sony Cyber-shot DSC-P9 LCD Replacement: 7 단계, 이미지 2/2
    • Unlatch the display by sliding it towards the circuit board.
  8. Sony Cyber-shot DSC-P9 LCD Replacement: 8 단계, 이미지 1/1
    • Remove the two ribbon cables attached to the circuit board by gently pulling them out of their slots.
    • Be careful not to rip the ribbon cables while disconnecting them.
  9. Sony Cyber-shot DSC-P9 LCD Replacement: 9 단계, 이미지 1/1
    • The LCD is now separated from the camera.
결론
Jenna Crawford
회원 가입일: 04/09/12
50 평판
안내서 3개 작성하였습니다
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G25
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 928
