주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-P9 Lens Replacement
필요한 것
  1. Sony Cyber-shot DSC-P9 Lens Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Lens Replacement: 2 단계, 이미지 1/1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Lens Replacement: 3 단계, 이미지 1/2 Sony Cyber-shot DSC-P9 Lens Replacement: 3 단계, 이미지 2/2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Lens Replacement, Outer Casing: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-P9 Lens Replacement, Outer Casing: 4 단계, 이미지 2/2
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Lens Replacement: 5 단계, 이미지 1/2 Sony Cyber-shot DSC-P9 Lens Replacement: 5 단계, 이미지 2/2
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Lens Replacement: 6 단계, 이미지 1/2 Sony Cyber-shot DSC-P9 Lens Replacement: 6 단계, 이미지 2/2
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Lens Replacement: 7 단계, 이미지 1/1
    • After the casing is removed, the camera should look as shown.
  8. Sony Cyber-shot DSC-P9 Lens Replacement, Lens: 8 단계, 이미지 1/2 Sony Cyber-shot DSC-P9 Lens Replacement, Lens: 8 단계, 이미지 2/2
    • Dislodge the round casing from the lens.
    • Pull it away from the rest of the camera.
  9. Sony Cyber-shot DSC-P9 Lens Replacement: 9 단계, 이미지 1/1
    • Unscrew the two 4.0mm Phillips #000 screws from the display.
  10. Sony Cyber-shot DSC-P9 Lens Replacement: 10 단계, 이미지 1/1
    • Pull the two ribbon cables out of their slots on the back circuit board.
  11. Sony Cyber-shot DSC-P9 Lens Replacement: 11 단계, 이미지 1/1
    • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
  12. Sony Cyber-shot DSC-P9 Lens Replacement: 12 단계, 이미지 1/3 Sony Cyber-shot DSC-P9 Lens Replacement: 12 단계, 이미지 2/3 Sony Cyber-shot DSC-P9 Lens Replacement: 12 단계, 이미지 3/3
    • Work the back panel out from under the small grey clip.
    • Slide the back panel off of the camera by dislodging it from the remaining clips.
    • Below is a flat, orange cable connecting the lens to the motherboard.
    • Be careful not to bend the back plate during this process.
  13. Sony Cyber-shot DSC-P9 Lens Replacement: 13 단계, 이미지 1/1
    • Turn the camera over so that you can see the front of the lens.
    • Two connectors link the lens to the motherboard.
    • Gently bring the lens away from the camera.
  14. Sony Cyber-shot DSC-P9 Lens Replacement: 14 단계, 이미지 1/1
    • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
    • Be careful not to exert too much force, as the connectors are delicate.
  15. Sony Cyber-shot DSC-P9 Lens Replacement: 15 단계, 이미지 1/3 Sony Cyber-shot DSC-P9 Lens Replacement: 15 단계, 이미지 2/3 Sony Cyber-shot DSC-P9 Lens Replacement: 15 단계, 이미지 3/3
    • Gently pull out the cables and move the lens away from the rest of the camera.
    • You should now have two distinct, separate components.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sean Sayles
회원 가입일: 05/09/12
7 평판
안내서 1개 작성함
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G25
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 1,384
