주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-P9 Outer Casing Replacement
필요한 것
  1. Sony Cyber-shot DSC-P9 Outer Casing Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Outer Casing Replacement: 2 단계, 이미지 1/1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Outer Casing Replacement: 3 단계, 이미지 1/2 Sony Cyber-shot DSC-P9 Outer Casing Replacement: 3 단계, 이미지 2/2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Outer Casing Replacement, Outer Casing: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-P9 Outer Casing Replacement, Outer Casing: 4 단계, 이미지 2/2
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Outer Casing Replacement: 5 단계, 이미지 1/2 Sony Cyber-shot DSC-P9 Outer Casing Replacement: 5 단계, 이미지 2/2
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Outer Casing Replacement: 6 단계, 이미지 1/2 Sony Cyber-shot DSC-P9 Outer Casing Replacement: 6 단계, 이미지 2/2
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Outer Casing Replacement: 7 단계, 이미지 1/1
    • After the casing is removed, the camera should look as shown.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jenna Crawford
회원 가입일: 04/09/12
50 평판
안내서 3개 작성하였습니다
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G25
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 802
