소개
Here is a straight forward repair of broken LCD. The repair should take no longer than 15 minutes. Replacement LCD's are available for under USD $20.
필요한 것
Remove the two Philips screws from the right side of the camera.
Remove the two Philips screws from the left side of the camera.
Split the housing by either using a plastic opening tool, or your finger nails. No excessive force is necessary. For ease of accomplishment, start at the battery compartment.
다른 4명이 해당 안내서를 완성하였습니다.
