주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-T1 CCD chip Replacement
필요한 것
  1. Sony Cyber-shot DSC-T1 CCD chip Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
  2. Sony Cyber-shot DSC-T1 CCD chip Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
  3. Sony Cyber-shot DSC-T1 CCD chip Replacement, CCD chip: 3 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-T1 CCD chip Replacement, CCD chip: 3 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-T1 CCD chip Replacement, CCD chip: 3 단계, 이미지 3개 중 3개
    • Locate and remove the 3mm screws on the bottom and sides of the camera with a JIS size #0 screwdriver.
  4. Sony Cyber-shot DSC-T1 CCD chip Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
  5. Sony Cyber-shot DSC-T1 CCD chip Replacement: 5 단계, 이미지 1개 중 1개
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it up. (If difficult, your fingernail can also be used)
  6. Sony Cyber-shot DSC-T1 CCD chip Replacement: 6 단계, 이미지 1개 중 1개
    • After releasing the clips, pull out the black lens box.
    • If the black lens box does not come out, go back to the previous step and make sure you released the correct clips.
  7. Sony Cyber-shot DSC-T1 CCD chip Replacement: 7 단계, 이미지 1개 중 1개
    • Locate and unscrew the two 3mm screws on the bottom of the black lens box with the JIS #0 screwdriver.
  8. Sony Cyber-shot DSC-T1 CCD chip Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • With the tweezers remove the black tape to detach the chip from the lens box.
  9. Sony Cyber-shot DSC-T1 CCD chip Replacement: 9 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-T1 CCD chip Replacement: 9 단계, 이미지 2개 중 2개
    • Grab the chip with your thumbs and carefully pull it off.
    • The copper tab will be glued to the lens box. Be careful not to rip it.
    • The attached copper ribbons are part of the CCD chip.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Rosario
회원 가입일: 04/12/12
48 평판
안내서 1개를 작성함
Cal Poly, Team 7-35, Maness Spring 2012 Cal Poly, Team 7-35, Maness Spring 2012 회원
CPSU-MANESS-S12S7G35
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 21
지난 30일: 59
전체 시간: 6,039
