소개
The flash bulb is the component of the camera responsible for illuminating the surroundings of the images. Replacing the flash bulb will require the removal of battery and black plastic housing that holds the CCD chip.
도구
부품
지정된 부품이 없습니다.
Locate the cover on the bottom of the camera.
Slide the cover towards the back of the camera.
Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
