이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the cover on the bottom of the camera.
Slide the cover towards the back of the camera.
Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
Pull the two halves of the camera apart.
Place the two halves down with the insides facing you.
Find the two clips holding the motherboard to the black lens box.
Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
Grab the white part and slide it to the right until it clicks.
Pull out the flash.
다른 한 분이 해당 안내서를 완성하였습니다.
