주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement
필요한 것
  1. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 3 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 3 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 3 단계, 이미지 3개 중 3개
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, CCD Sensor Module: 5 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, CCD Sensor Module: 5 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Grasp the CCD Sensor Module and remove it.
  7. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Flash Module: 7 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Flash Module: 7 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Flash Module: 7 단계, 이미지 3개 중 3개
    • This camera houses a very strong capacitor (the black cylinder). Avoid touching anything around the two wires coming out of the top. Doing so will risk serious electric shock.
    • Carefully disengage the internal components from the casing by lifting at the bottom end and giving a gentle tug.
    • The components are still connected to the casing via cables, but they are much more maneuverable.
    • The flash module is shown on the right hand side.
  8. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: 8 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to flip up the tab on the ZIF connecter securing the motherboard ribbon cable.
    • Grasp the flash module by the bottom and remove it.
  9. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Motherboard Assembly: 9 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Motherboard Assembly: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to slide the white piece on the back of the back cover to the right.
    • This will dislodge the white piece, allowing you to remove it from the back cover.
  10. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the ribbon cables from these two ZIF connectors.
  11. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: 11 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: 11 단계, 이미지 2개 중 2개
    • Lift the motherboard assembly up and rotate it so you can easily see where the internals connect to the back cover.
    • Remove the ZIF connectors from the clamp on the left end of the top piece.
    • The motherboard assembly is now separated from the back cover.
결론
작성자
10다른 기여자 명과 함께
iDeleted
회원 가입일: 07/07/10
2,101 평판
안내서 39개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 11
전체 시간: 2,343
