주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-T1 Motherboard Replacement
필요한 것
  1. Sony Cyber-shot DSC-T1 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Sony Cyber-shot DSC-T1 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 Motherboard Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 3 단계, 이미지 1/3 Sony Cyber-shot DSC-T1 Motherboard Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 3 단계, 이미지 2/3 Sony Cyber-shot DSC-T1 Motherboard Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 3 단계, 이미지 3/3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 Motherboard Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-T1 Motherboard Replacement: 4 단계, 이미지 2/2
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 Motherboard Replacement, CCD Sensor Module: 5 단계, 이미지 1/2 Sony Cyber-shot DSC-T1 Motherboard Replacement, CCD Sensor Module: 5 단계, 이미지 2/2
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 Motherboard Replacement: 6 단계, 이미지 1/1
    • Grasp the CCD Sensor Module and remove it.
  7. Sony Cyber-shot DSC-T1 Motherboard Replacement, Flash Module: 7 단계, 이미지 1/3 Sony Cyber-shot DSC-T1 Motherboard Replacement, Flash Module: 7 단계, 이미지 2/3 Sony Cyber-shot DSC-T1 Motherboard Replacement, Flash Module: 7 단계, 이미지 3/3
    • This camera houses a very strong capacitor (the black cylinder). Avoid touching anything around the two wires coming out of the top. Doing so will risk serious electric shock.
    • Carefully disengage the internal components from the casing by lifting at the bottom end and giving a gentle tug.
    • The components are still connected to the casing via cables, but they are much more maneuverable.
    • The flash module is shown on the right hand side.
  8. Sony Cyber-shot DSC-T1 Motherboard Replacement: 8 단계, 이미지 1/2 Sony Cyber-shot DSC-T1 Motherboard Replacement: 8 단계, 이미지 2/2
    • Use the tip of a spudger to flip up the tab on the ZIF connecter securing the motherboard ribbon cable.
    • Grasp the flash module by the bottom and remove it.
  9. Sony Cyber-shot DSC-T1 Motherboard Replacement, Motherboard Assembly: 9 단계, 이미지 1/2 Sony Cyber-shot DSC-T1 Motherboard Replacement, Motherboard Assembly: 9 단계, 이미지 2/2
    • Use tweezers to slide the white piece on the back of the back cover to the right.
    • This will dislodge the white piece, allowing you to remove it from the back cover.
  10. Sony Cyber-shot DSC-T1 Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the ribbon cables from these two ZIF connectors.
  11. Sony Cyber-shot DSC-T1 Motherboard Replacement: 11 단계, 이미지 1/2 Sony Cyber-shot DSC-T1 Motherboard Replacement: 11 단계, 이미지 2/2
    • Lift the motherboard assembly up and rotate it so you can easily see where the internals connect to the back cover.
    • Remove the ZIF connectors from the clamp on the left end of the top piece.
    • The motherboard assembly is now separated from the back cover.
  12. Sony Cyber-shot DSC-T1 Motherboard Replacement, Motherboard: 12 단계, 이미지 1/1
    • Locate the screw inside the small white piece on the motherboard assembly.
    • Remove this 2.9mm screw using a PH00 screwdriver.
  13. Sony Cyber-shot DSC-T1 Motherboard Replacement: 13 단계, 이미지 1/1
    • Use tweezers to remove the small white piece from the motherboard assembly.
  14. Sony Cyber-shot DSC-T1 Motherboard Replacement: 14 단계, 이미지 1/1
    • Turn the motherboard assembly over.
    • Use a spudger to open the ZIF connector on the motherboard.
    • Remove the ribbon cables from the opened clip.
  15. Sony Cyber-shot DSC-T1 Motherboard Replacement: 15 단계, 이미지 1/2 Sony Cyber-shot DSC-T1 Motherboard Replacement: 15 단계, 이미지 2/2
    • Pry the motherboard slightly apart form the motherboard assembly.
    • Be careful while separating the board so that you do not damage the ribbon cables or other components.
    • Disconnect the ribbon cable connecting the battery pack to the motherboard.
  16. Sony Cyber-shot DSC-T1 Motherboard Replacement: 16 단계, 이미지 1/3 Sony Cyber-shot DSC-T1 Motherboard Replacement: 16 단계, 이미지 2/3 Sony Cyber-shot DSC-T1 Motherboard Replacement: 16 단계, 이미지 3/3
    • Pull the motherboard up from the battery pack and flip the motherboard assembly over.
    • Use a PH00 screwdriver to remove the 2.9mm screw connecting the speaker to the battery pack.
결론
iDeleted
회원 가입일: 07/07/10
2,101 평판
안내서 39개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 2,422
