주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-T500 LCD Screen Replacement
필요한 것
  1. Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Case Screws: 1 단계, 이미지 1/2 Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Case Screws: 1 단계, 이미지 2/2
    • There are 4 screws total holding the outer shell of the camera. One on each corner. To reach the bottom two, you have to slide the camera cover up. Vise versa for the top two.
    • Make sure to remove the battery before taking the camera apart.
  2. Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Back Panel: 2 단계, 이미지 1/2 Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Back Panel: 2 단계, 이미지 2/2
    • Separate the front and back housings carefully.
    • Be careful not to pry it apart as they are connected together by the LCD ribbon cables.
    • Once you have separated the two housings unplug the LCD ribbon cables.
    • There should be three. One big one and two small ones
    • Remove the LCD screen from the housing.
    • You'll have to carefully lift the internal components of the camera in order to remove the LCD screen.
결론
Chelsea Vitone
회원 가입일: 01/21/15
213 평판
안내서 2개 작성하였습니다
UWT Liner: Group 4 UWT Liner: Group 4 회원
Community
6 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 23
전체 시간: 469
