주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-T9 AV Port Replacement
필요한 것
  1. Sony Cyber-shot DSC-T9 AV Port Replacement, Battery: 1 단계, 이미지 1/1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 AV Port Replacement: 2 단계, 이미지 1/1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 AV Port Replacement, Back Cover: 3 단계, 이미지 1/1
    • This is the camera without the front cover.
  4. Sony Cyber-shot DSC-T9 AV Port Replacement: 4 단계, 이미지 1/1
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  5. Sony Cyber-shot DSC-T9 AV Port Replacement: 5 단계, 이미지 1/3 Sony Cyber-shot DSC-T9 AV Port Replacement: 5 단계, 이미지 2/3 Sony Cyber-shot DSC-T9 AV Port Replacement: 5 단계, 이미지 3/3
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  6. Sony Cyber-shot DSC-T9 AV Port Replacement: 6 단계, 이미지 1/3 Sony Cyber-shot DSC-T9 AV Port Replacement: 6 단계, 이미지 2/3 Sony Cyber-shot DSC-T9 AV Port Replacement: 6 단계, 이미지 3/3
    • Pull apart the inner hardware from the back case by prying on the left side.
  7. Sony Cyber-shot DSC-T9 AV Port Replacement: 7 단계, 이미지 1/1
    • Remove the back cover.
  8. Sony Cyber-shot DSC-T9 AV Port Replacement: 8 단계, 이미지 1/1
    • The back cover is now removed from the internal hardware.
  9. Sony Cyber-shot DSC-T9 AV Port Replacement, CCD Module: 9 단계, 이미지 1/1
    • This is the CCD module.
  10. Sony Cyber-shot DSC-T9 AV Port Replacement: 10 단계, 이미지 1/1
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  11. Sony Cyber-shot DSC-T9 AV Port Replacement: 11 단계, 이미지 1/1
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  12. Sony Cyber-shot DSC-T9 AV Port Replacement: 12 단계, 이미지 1/1
    • The CCD module is now removed from the camera.
  13. Sony Cyber-shot DSC-T9 AV Port Replacement, AV Port: 13 단계, 이미지 1/2 Sony Cyber-shot DSC-T9 AV Port Replacement, AV Port: 13 단계, 이미지 2/2
    • These two screws hold in the AV port.
    • Use Phillips screwdriver to remove screws.
  14. Sony Cyber-shot DSC-T9 AV Port Replacement: 14 단계, 이미지 1/1
    • Remove metal screw plate.
  15. Sony Cyber-shot DSC-T9 AV Port Replacement: 15 단계, 이미지 1/1
    • Use pry stick to pop off ribbon.
  16. Sony Cyber-shot DSC-T9 AV Port Replacement: 16 단계, 이미지 1/1
    • Remove AV port from camera.
결론
Stephannie Allen
회원 가입일: 03/11/13
255 평판
안내서 10개 작성하였습니다
Clemson, Team 13-1, Benson Spring 2013 Clemson, Team 13-1, Benson Spring 2013 회원
CLEM-BENSON-S13S13G1
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 619
