주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-T9 Front Cover Replacement
필요한 것
  1. Sony Cyber-shot DSC-T9 Front Cover Replacement, Battery: 1 단계, 이미지 1/1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 Front Cover Replacement: 2 단계, 이미지 1/1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 Front Cover Replacement, Front Cover: 3 단계, 이미지 1/3 Sony Cyber-shot DSC-T9 Front Cover Replacement, Front Cover: 3 단계, 이미지 2/3 Sony Cyber-shot DSC-T9 Front Cover Replacement, Front Cover: 3 단계, 이미지 3/3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 Front Cover Replacement: 4 단계, 이미지 1/1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 Front Cover Replacement: 5 단계, 이미지 1/1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 Front Cover Replacement: 6 단계, 이미지 1/1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Stephannie Allen
회원 가입일: 03/11/13
255 평판
안내서 10개 작성하였습니다
Clemson, Team 13-1, Benson Spring 2013 Clemson, Team 13-1, Benson Spring 2013 회원
CLEM-BENSON-S13S13G1
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 417
