주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement
필요한 것
  1. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: 1 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: 1 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: 1 단계, 이미지 3개 중 3개
    • Remove the battery
    • Remove the five 2.5mm Philips #0 screws.
    • Remove the one 2.5mm Philips #0 screw inside the HDMI case.
  2. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Gently work and pull the front cover off of the camera
  3. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Gently pull and disconnect the ribbon cable connecting the front cover to the main body
  4. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 4 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 4 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    iSesamo Opening Tool
    $9.99
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry off the cover of the OLED/LCD assembly.
    • Take care of the tab/clip at the bottom, it can be a little tricky.
    • iSesamo Opening Tool is highly recommended
  5. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 5 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the copper phillips screw holding the HDMI mounting plate and detach the mounting plate.
  6. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 6 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 6 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $9.99
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry the OLED/LCD assembly from the adhesive strip on the main body.
    • Note: where the adhesive strip is located.
    • Turn the device over and remove the clear tape and black tape.
    • Important: Save the clear and black tape, they will be used for the replacement unit.
  7. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Gently pull the small flat ribbon cable from the main body
    • In order to disconnect the large flat ribbon cable, you need to flip up the black ribbon clamp located on the main body where the socket is located
  8. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Reattach new display, and reconnect all components
    • Test camera to ensure the new screen is working
    • Congrats!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tim
회원 가입일: 03/12/12
2,217 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 17
전체 시간: 4,853
