주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-TX55 Back Case Replacement
필요한 것
  1. Sony Cyber-shot DSC-TX55 Back Case Replacement, Back Case: 1 단계, 이미지 1/1
    • Using your Phillips #00 screwdriver, remove all four 0.3 cm screws that are located on both ends, as well as the bottom of your Cyber-Shot
  2. Sony Cyber-shot DSC-TX55 Back Case Replacement: 2 단계, 이미지 1/1
    • Using your right hand, gently pull back the back metal frame of your device.
  3. Sony Cyber-shot DSC-TX55 Back Case Replacement: 3 단계, 이미지 1/1
    • The back case of the device is the metal frame.
결론
Megan East
회원 가입일: 10/13/15
555 평판
안내서 5개 작성하였습니다
Sam Houston State, Team 2-5, Blackburne Fall 2015 Sam Houston State, Team 2-5, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 434
