주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-TX55 Front Case Replacement
필요한 것
  1. Sony Cyber-shot DSC-TX55 Front Case  Replacement, Front Case: 1 단계, 이미지 1/1
    • Using the Phillips #00 Screwdriver, remove all of the 0.3 cm screws from both left and right panels.
  2. Sony Cyber-shot DSC-TX55 Front Case  Replacement: 2 단계, 이미지 1/1
    • Gently remove the back cover.
  3. Sony Cyber-shot DSC-TX55 Front Case  Replacement: 3 단계, 이미지 1/1
    • You may need to use some force to remove the front case due to it being stiff.
  4. Sony Cyber-shot DSC-TX55 Front Case  Replacement: 4 단계, 이미지 1/1
    • Follow the steps in reverse order with the new front case to complete the replacement.
결론
Megan East
회원 가입일: 10/13/15
555 평판
안내서 5개 작성하였습니다
Sam Houston State, Team 2-5, Blackburne Fall 2015 Sam Houston State, Team 2-5, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 413
