주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-TX55 LCD Screen Replacement
필요한 것
  1. Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/3 Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2/3 Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3/3
    • Slide open the battery cover in the direction that the arrows on device are pointing.
    • Flip the blue battery lock to eject the battery.
    • Remove the battery from the device.
  2. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Using your Phillips #00 screwdriver, remove all four 0.3 cm screws that are located on both ends, as well as the bottom of your Cyber-Shot.
    • Make sure that your screws are placed on a flat, still surface so they do not roll away.
  3. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Gently pull away the back end of the camera where the LCD screen is located.
    • Remove the metal frame that is located around the LCD screen.
  4. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 4 단계, 이미지 1/1
    • Remove the front cover.
  5. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Gently remove the lens from the device.
    • The lens will hang on by the orange strips, be careful not to tug on the lens.
  6. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 6 단계, 이미지 1/2 Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 6 단계, 이미지 2/2
    • Gently slide the LCD screen using very light pressure to the right until it pops open.
  7. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 7 단계, 이미지 1/1
    • The LCD screen will open to the right.
    • Remove the orange tab from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Megan East
회원 가입일: 10/13/15
555 평판
안내서 5개 작성하였습니다
Sam Houston State, Team 2-5, Blackburne Fall 2015 Sam Houston State, Team 2-5, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 35
전체 시간: 1,800
