주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W230 LCD Display Screen Replacement
필요한 것
  1. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement, Separating Camera and Display: 1 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement, Separating Camera and Display: 1 단계, 이미지 2개 중 2개
    • Align the camera so that the side with "4x Optical Zoom" is facing toward you.
    • Gently twist the bottom corner clockwise until you feel the side panel unlock.
    • Lift off the side panel and set aside.
  2. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 2 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Rotate the camera 180 degrees to face the side panel with the lanyard loop on it.
    • Gently lift the panel vertically until it lifts off
    • Take care to not lose the small rectangular portion on the bottom of the panel.
  3. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 3 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 3 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Position the camera so the bottom is facing up and the display away from the surface.
    • Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
    • Do not fully separate the two components! the screen is attached by two ribbon cables.
    • Lay the display flat to expose the circuit board and the display control ribbon cables.
  4. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement, LCD Display Screen: 4 단계, 이미지 1개 중 1개
    • Using a flat head screw driver gently pry up the tab securing the ribbon cable from the display screen to the camera sensor and battery housing.
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing
    • Following the same procedure as above, uninstall the ribbon cable connecting the main camera controls to the camera sensor and battery housing
  5. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 5 단계, 이미지 1개 중 1개
    • The LCD display screen is now removed from the camera sensor and battery housing.
    • The main camera controls are now removed from the camera sensor and battery housing.
  6. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Unsnap LCD display screen from its mount by unsnapping it from the display screen using your finger nail.
    • Now the new LCD screen can be installed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Michael Henry
회원 가입일: 03/09/12
21 평판
안내서 1개를 작성함
Clemson, Team 2-3, Benson Spring 2012 Clemson, Team 2-3, Benson Spring 2012 회원
CLEM-BENSON-S12S2G3
3 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 33
전체 시간: 4,498
