이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Begin by placing the camera upside down and removing the three small center screws.
Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel.
Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
Locate the camera's tripod mount located on the bottom of the camera.
Carefully remove the camera's tripod mount and place it aside.
Be careful not to lose this piece.
Rotate the silver panel labeled 4x clockwise.
Align the camera so that the side with "4x Optical Zoom" is facing toward you.
Gently twist the bottom corner clockwise until you feel the side panel unlock.
Lift off the side panel and set aside.
Rotate the camera 180 degrees to face the side panel with the lanyard loop on it.
Gently lift the panel vertically until it lifts off
Position the camera so the bottom is facing up and the display away from the surface.
Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
Lay the display flat to expose the circuit board and the display control ribbon cables.
Using a flat head screw driver gently pry up on the tab securing the larger ribbon cable which connects the display screen and camera sensor / battery housing.
Remove the ribbon cable connecting the LCD display and camera sensor / battery housing.
Following the same procedure, uninstall the ribbon cable connecting the main camera controls to the camera sensor and battery housing
Now turn your attention to the camera sensor and battery housing. Identify the two connection points of the large ribbon cable.
Carefully place a flathead screwdriver under the left ribbon cable connection point and pull up to disconnect.
Repeat the previous step but this time carefully remove the right ribbon cable connection point.
After both sides of the ribbon cable have been disconnected it is ready to be replaced.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
The locking meachanism on the Monitors ribbon cable is broken on my camera.
It pivots and locks the ribbon down to create a secure connection. However, because of the Brocken lock one side is not locked down therefore the Monitor turns off when tapped.
Is there a place that I could get a replacement for this lock?
much appreciated.
