주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W290 LCD Assembly Replacement
필요한 것
  1. Sony Cyber-shot DSC-W290 LCD Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 2 단계, 이미지 1/1
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Sony Cyber-shot DSC-W290 LCD Assembly Replacement, Outer Casing: 3 단계, 이미지 1/2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement, Outer Casing: 3 단계, 이미지 2/2
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 4 단계, 이미지 1/3 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 4 단계, 이미지 2/3 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 4 단계, 이미지 3/3
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 5 단계, 이미지 1/3 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 5 단계, 이미지 2/3 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 5 단계, 이미지 3/3
    • Turn the camera so the right side faces you.
  6. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 6 단계, 이미지 1/1
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 7 단계, 이미지 1/2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 7 단계, 이미지 2/2
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 8 단계, 이미지 1/2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 8 단계, 이미지 2/2
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 9 단계, 이미지 1/2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 9 단계, 이미지 2/2
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 10 단계, 이미지 1/2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 10 단계, 이미지 2/2
    • This is what your camera should look like now that you have removed the casing from all sides.
  11. Sony Cyber-shot DSC-W290 LCD Assembly Replacement, LCD Assembly: 11 단계, 이미지 1/1
    • Gently pull the LCD and its casing away from the motherboard as shown.
    • Be careful not to rip out any ribbon cables.
  12. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 12 단계, 이미지 1/2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 12 단계, 이미지 2/2
    • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
    • Do not use excessive force to remove the wire because this may cause it to tear.
    Caution: Do NOT attempt to remove the logic board itself until the LCD is completely off.
    Sanat Sahasrabudhe - 답글
  13. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 13 단계, 이미지 1/2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 13 단계, 이미지 2/2
    • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
  14. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 14 단계, 이미지 1/1
    • Pull the LCD and its casing away from the rest of the camera.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Evan Mayer
회원 가입일: 10/05/10
318 평판
안내서 5개 작성하였습니다
Cal Poly, Team 7-54, Amido Fall 2010 Cal Poly, Team 7-54, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G54
4 회원들
안내서 16개 작성하였습니다
댓글 2개
where can i get a replacement screen but one that isn't that expensive~
jenna - 답글
At Step 13, when re-assembling, insert the large ribbon into the slot using fingers then seat as far in as possible by pushing on each side gently, using tweezers.
Christopher Bell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 16
전체 시간: 6,600
