주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W290 casing Replacement
필요한 것
  1. Sony Cyber-shot DSC-W290 casing Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Sony Cyber-shot DSC-W290 casing Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Sony Cyber-shot DSC-W290 casing Replacement, Outer Casing: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W290 casing Replacement, Outer Casing: 3 단계, 이미지 2개 중 2개
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Sony Cyber-shot DSC-W290 casing Replacement: 4 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W290 casing Replacement: 4 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W290 casing Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Sony Cyber-shot DSC-W290 casing Replacement: 5 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W290 casing Replacement: 5 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W290 casing Replacement: 5 단계, 이미지 3개 중 3개
    • Turn the camera so the right side faces you.
  6. Sony Cyber-shot DSC-W290 casing Replacement: 6 단계, 이미지 1개 중 1개
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Sony Cyber-shot DSC-W290 casing Replacement: 7 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W290 casing Replacement: 7 단계, 이미지 2개 중 2개
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Sony Cyber-shot DSC-W290 casing Replacement: 8 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W290 casing Replacement: 8 단계, 이미지 2개 중 2개
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Sony Cyber-shot DSC-W290 casing Replacement: 9 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W290 casing Replacement: 9 단계, 이미지 2개 중 2개
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Sony Cyber-shot DSC-W290 casing Replacement: 10 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W290 casing Replacement: 10 단계, 이미지 2개 중 2개
    • This is what your camera should look like now that you have removed the casing from all sides.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Evan Mayer
회원 가입일: 10/05/10
336 평판
안내서 5개를 작성함
Cal Poly, Team 7-54, Amido Fall 2010 Cal Poly, Team 7-54, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G54
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 2,072
