주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W5 Motherboard Replacement
필요한 것
  1. Sony Cyber-shot DSC-W5 Motherboard Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Sony Cyber-shot DSC-W5 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W5 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Sony Cyber-shot DSC-W5 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W5 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Sony Cyber-shot DSC-W5 Motherboard Replacement, LCD Screen: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W5 Motherboard Replacement, LCD Screen: 4 단계, 이미지 2개 중 2개
    • Remove the two screws holding the circuit board down.
  5. Sony Cyber-shot DSC-W5 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Sony Cyber-shot DSC-W5 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W5 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Sony Cyber-shot DSC-W5 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W5 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W5 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
  8. Sony Cyber-shot DSC-W5 Motherboard Replacement, Speaker: 8 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W5 Motherboard Replacement, Speaker: 8 단계, 이미지 2개 중 2개
    • Remove the two screws holding down the steel back plate.
    • Remove steel back plate.
  9. Sony Cyber-shot DSC-W5 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W5 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Now remove the plastic plate that covers the motherboard.
  10. Sony Cyber-shot DSC-W5 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W5 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Warning: Electric Shock From this point on, hold the camera by the chrome edges ONLY. Capacitors store electric charge even if the batteries are removed.
    • Remove the blue cable.
  11. Sony Cyber-shot DSC-W5 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W5 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Disconnect the flash cable (black and white wires) before completely removing the front case.
    • Gently start to remove the case.
    • Once the cable is free, set aside the front case.
  12. Sony Cyber-shot DSC-W5 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W5 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • The speaker should now be clearly seen on the underside of the camera.
    • Gently unplug the speaker from the motherboard.
    • Replace the speaker.
  13. Sony Cyber-shot DSC-W5 Motherboard Replacement, Battery Terminal: 13 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W5 Motherboard Replacement, Battery Terminal: 13 단계, 이미지 2개 중 2개
    • Remove the orange cable connecting the battery terminal to the motherboard.
  14. Sony Cyber-shot DSC-W5 Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • The battery terminal is now free from the board and can be slid out.
  15. Sony Cyber-shot DSC-W5 Motherboard Replacement, Lens: 15 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W5 Motherboard Replacement, Lens: 15 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W5 Motherboard Replacement, Lens: 15 단계, 이미지 3개 중 3개
    • Detach two cables that go from the motherboard to the lens.
    • Remove lens.
  16. Sony Cyber-shot DSC-W5 Motherboard Replacement, Motherboard: 16 단계, 이미지 1개 중 1개
    • After the lens is detached, you can replace the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Thomas
회원 가입일: 04/14/10
157 평판
안내서 6개를 작성함
Cal Poly, Team 15-50, Garner Spring 2010 Cal Poly, Team 15-50, Garner Spring 2010 회원
CPSU-GARNER-S10S15G50
5 회원들
안내서 12개를 작성함
1가이드 댓글
Thank yo very much, Muy agradecido por la información. Good information fireman4792000@yahoo.com
Jorge - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 14
전체 시간: 5,971
