주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W55 Flash Assembly Replacement
필요한 것
  1. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
    My battery stuck in the camera
    Farida Easmin - 답글
    My battery is stuck in the camera
    Farida Easmin - 답글
  2. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 2 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Back Case: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Back Case: 3 단계, 이미지 2개 중 2개
    • Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
    • Remove the panel.
  5. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 6 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
    Muchas gracias, muy claro!!
    Ruben - 답글
  7. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Front Case: 7 단계, 이미지 1개 중 1개
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 8 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 8 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Lens: 9 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Lens: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 10 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Gently pull the lens container out of the camera.
  11. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Motherboard - First Half: 11 단계, 이미지 1개 중 1개
    • Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
  12. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 12 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 12 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the two orange cables on the top of the motherboard with tweezers.
    • Lift the motherboard out of its slot.
  13. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 13 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 13 단계, 이미지 2개 중 2개
    • For the AV port, detach the bottom orange cable.
    • For the LCD screen, detach the top orange cable on the right side of the motherboard.
    • For the motherboard, detach all the orange cables.
    • Careful not to damage the red, white, and black wires when lifting the board.
  14. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, LCD Screen: 14 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement, LCD Screen: 14 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement, LCD Screen: 14 단계, 이미지 3개 중 3개
    • Verify the orange cables from the motherboard are removed from the LCD screen.
    • Lift the LCD screen off the hinge.
  15. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 15 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 15 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 15 단계, 이미지 3개 중 3개
    • Verify that the LCD screen is attached to the chip on the back on the camera.
    • Remove the dial from the back of the camera. It pops right off very easily.
    • Remove the screw using a Phillips #00 Screwdriver from the camera.
  16. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 16 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the orange cable that is attached between the top of the camera and the chip. It should slide straight out with a little bit of force.
    • Remove the chip and the LCD screen now from the camera.
    • The chip may need a slight upward tug with a fingernail or tweezer.
  17. Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Flash Assembly: 17 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement, Flash Assembly: 17 단계, 이미지 2개 중 2개
    • Verify that the orange cables from the top piece are removed from the motherboard.
    • Remove the screw using a Phillips #00 Screwdriver on the upper part of the back side.
    • Pull the top off slowly and with caution. It is still slightly attached and may need a little force.
  18. Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 18 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W55 Flash Assembly Replacement: 18 단계, 이미지 2개 중 2개
    • Slowly twist out the flash assembly.
    • It is attached to the hinge so a little force is necessary.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Eddie Lo
회원 가입일: 10/11/10
334 평판
안내서 4개를 작성함
Cal Poly, Team 9-20, Regan Fall 2010 Cal Poly, Team 9-20, Regan Fall 2010 회원
CPSU-REGAN-F10S9G20
5 회원들
안내서 18개를 작성함
댓글 한 개
LensK pati lagwana hai
Sahil Singh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 34
전체 시간: 9,225
