주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W55 Front Case Replacement
필요한 것
  1. Sony Cyber-shot DSC-W55 Front Case Replacement, Battery: 1 단계, 이미지 1/2 Sony Cyber-shot DSC-W55 Front Case Replacement, Battery: 1 단계, 이미지 2/2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Front Case Replacement: 2 단계, 이미지 1/2 Sony Cyber-shot DSC-W55 Front Case Replacement: 2 단계, 이미지 2/2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Front Case Replacement, Back Case: 3 단계, 이미지 1/2 Sony Cyber-shot DSC-W55 Front Case Replacement, Back Case: 3 단계, 이미지 2/2
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Front Case Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-W55 Front Case Replacement: 4 단계, 이미지 2/2
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Front Case Replacement: 5 단계, 이미지 1/1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Front Case Replacement: 6 단계, 이미지 1/2 Sony Cyber-shot DSC-W55 Front Case Replacement: 6 단계, 이미지 2/2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Sony Cyber-shot DSC-W55 Front Case Replacement, Front Case: 7 단계, 이미지 1/1
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 Front Case Replacement: 8 단계, 이미지 1/3 Sony Cyber-shot DSC-W55 Front Case Replacement: 8 단계, 이미지 2/3 Sony Cyber-shot DSC-W55 Front Case Replacement: 8 단계, 이미지 3/3
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Carter
회원 가입일: 10/11/10
202 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-20, Regan Fall 2010 Cal Poly, Team 9-20, Regan Fall 2010 회원
CPSU-REGAN-F10S9G20
5 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 13
전체 시간: 3,375
