이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
We are going to explain the steps needed and what is necessary in order to replace a broken front cover for this camera.
필요한 것
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw using a Phillips #00 Screwdriver on the left side (where the "3x optical zoom" panel use to be).
다른 한 분이 해당 안내서를 완성하였습니다.
