소개
This guide shows step by step instructions to remove the lens part of the camera.
부품
지정된 부품이 없습니다.
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw using a Phillips #00 screwdriver on the left side (where the "3x optical zoom" panel use to be).
다른 14명이 해당 안내서를 완성하였습니다.
댓글 2개
Thanks for this guide !
unfortunatly I thinks that my lens is broken (doesn't open anymore, it may have sand inside it)
Do you know where an if I can buy a new lens ?
Thanks for info..
Need a broken lens unit as my lens cable is broken, email me if any one wants to sell a broken lens unit. at barrettoagnelo@yahoo.com
