주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W570 Battery Replacement
  1. Sony Cyber-shot DSC-W570 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the camera upside down.
    • Locate the lock bar and slide to 'open' position.
    • No tools required.
  2. Sony Cyber-shot DSC-W570 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Press the blue clip forward, releasing the battery.
    • Remove the battery and replace it with a new one.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Anthony
회원 가입일: 01/21/15
147 평판
안내서 1개를 작성함
USF Tampa, Team 9-1, Brown Winter 2015 USF Tampa, Team 9-1, Brown Winter 2015 회원
USFT-BROWN-W15S9G1
5 회원들
안내서 10개를 작성함
1가이드 댓글
Thank you so much. In many moves, my battery charger was lost and it had been a long time before I came across the camera and wondered if I could get a new charger. It was so confusing. Now I'm not sure why I'm to get a charger when you need to buy a new battery? Now that's still confusing. But at least I know where and how to remove the battery. Thank you. Your instructions were so clear even I, at 75, could figure out what to do.
Pat Quackenbush - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 52
전체 시간: 2,895
