주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W570 Case Cover Replacement
필요한 것
  1. Sony Cyber-shot DSC-W570 Case Cover Replacement, Case Cover: 1 단계, 이미지 1/1
    • Remove the two Phillips head, 2.93 mm long screws at the bottom of the camera.
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 Case Cover Replacement: 2 단계, 이미지 1/1
    • Turn the camera sideways so the left side is fasning upwards, remove the two Phillips head, 2.93 mm screws.
  3. Sony Cyber-shot DSC-W570 Case Cover Replacement: 3 단계, 이미지 1/1
    • Now turn the device so the opposite side is fasning upwards and remove the last two Phillips head, 2.93 mm screws.
  4. Sony Cyber-shot DSC-W570 Case Cover Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-W570 Case Cover Replacement: 4 단계, 이미지 2/2
    • To remove the front cover, use a plastic opening tool gently pry the top cover.
    • Then gently lift the cover off.
  5. Sony Cyber-shot DSC-W570 Case Cover Replacement: 5 단계, 이미지 1/2 Sony Cyber-shot DSC-W570 Case Cover Replacement: 5 단계, 이미지 2/2
    • To remove the back case cover from the body.
    • First use a plastic opening tool gently pry along the side of the camera.
    • Then slowly and gently lift the cover off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zizheng Su
회원 가입일: 01/21/15
101 평판
안내서 1개 작성함
USF Tampa, Team 9-1, Brown Winter 2015 USF Tampa, Team 9-1, Brown Winter 2015 회원
USFT-BROWN-W15S9G1
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 18
전체 시간: 731
