주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W570 Case Cover Replacement
필요한 것
  1. Sony Cyber-shot DSC-W570 Case Cover Replacement, Case Cover: 1 단계, 이미지 1개 중 1개
    • Begin by facing the camera bottom side up to reveal the two 2.93 mm long screws
    • Remove these two screws using a Philips #00 screwdriver
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 Case Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the camera sideways on its left side making sure the two 2.93 mm long screws are facing upwards
    • Remove the two 2.93 mm long screws using a Phillips #00 screwdriver
    • Keep all screws on stable surface to not loose them
  3. Sony Cyber-shot DSC-W570 Case Cover Replacement: 3 단계, 이미지 1개 중 1개
    • Turn the camera on its right side making sure it is facing upwards
    • Remove the last two 2.93 mm long screws using a Phillips #00 screwdriver
  4. Sony Cyber-shot DSC-W570 Case Cover Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W570 Case Cover Replacement: 4 단계, 이미지 2개 중 2개
    • Face the device with the camera lens facing upwards
    • Now that all the screws are unscrewed, the plastic opening tool will be used to remove the front cover.
    • Gently pry off each corner of the cover to remove it
    • Once all corners are pried off, gently lift off the cover and place it on the side
  5. Sony Cyber-shot DSC-W570 Case Cover Replacement: 5 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W570 Case Cover Replacement: 5 단계, 이미지 2개 중 2개
    • Flip the device, making sure the screen is facing upwards
    • The back case should now be visible and ready to remove
    • Use the plastic opening tool to gently pry all along the corners and sides of the camera.
    • Gently lift off the entire back cover and place it on the side
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Zizheng Su
회원 가입일: 01/21/15
101 평판
안내서 1개를 작성함
USF Tampa, Team 9-1, Brown Winter 2015 USF Tampa, Team 9-1, Brown Winter 2015 회원
USFT-BROWN-W15S9G1
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 11
전체 시간: 944
