주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W570 Flash Replacement
필요한 것
  1. Sony Cyber-shot DSC-W570 Flash Replacement, Case Cover: 1 단계, 이미지 1/1
    • Remove the two Phillips head, 2.93 mm long screws at the bottom of the camera.
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 Flash Replacement: 2 단계, 이미지 1/1
    • Turn the camera sideways so the left side is fasning upwards, remove the two Phillips head, 2.93 mm screws.
  3. Sony Cyber-shot DSC-W570 Flash Replacement: 3 단계, 이미지 1/1
    • Now turn the device so the opposite side is fasning upwards and remove the last two Phillips head, 2.93 mm screws.
  4. Sony Cyber-shot DSC-W570 Flash Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-W570 Flash Replacement: 4 단계, 이미지 2/2
    • To remove the front cover, use a plastic opening tool gently pry the top cover.
    • Then gently lift the cover off.
  5. Sony Cyber-shot DSC-W570 Flash Replacement: 5 단계, 이미지 1/2 Sony Cyber-shot DSC-W570 Flash Replacement: 5 단계, 이미지 2/2
    • To remove the back case cover from the body.
    • First use a plastic opening tool gently pry along the side of the camera.
    • Then slowly and gently lift the cover off.
  6. Sony Cyber-shot DSC-W570 Flash Replacement, LCD Screen: 6 단계, 이미지 1/1
    • These are the two cables connecting the LCD screen to the motherboard below the screen.
  7. Sony Cyber-shot DSC-W570 Flash Replacement: 7 단계, 이미지 1/1
    • Remove the LCD screen from the side opppsite the battery terminals. Watch for the two cords mentioned in the previous step. These will still be connected.The side will flip up as shown in the next step.
  8. Sony Cyber-shot DSC-W570 Flash Replacement: 8 단계, 이미지 1/1
    • Pull these two cords straight back to disconnect them from the respective housings. Caution: The housing do not need to be moved or adjusted in anyway. Do not pull the cords at an angle, it can destroy the cords and the housing. Pull Straight Back!
  9. Sony Cyber-shot DSC-W570 Flash Replacement: 9 단계, 이미지 1/1
    • This is what the camera should look like after 2 cords and the screen have been removed. The lens cord is being held to the side for a clearer view.
  10. Sony Cyber-shot DSC-W570 Flash Replacement, Flash: 10 단계, 이미지 1/1
    • These are buttons for menu. Be sure to check that the flash settings are correct for your scene. Do not replace flash until settings are verified.
  11. Sony Cyber-shot DSC-W570 Flash Replacement: 11 단계, 이미지 1/2 Sony Cyber-shot DSC-W570 Flash Replacement: 11 단계, 이미지 2/2
    • Caution: Touching the capacitor wires may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • After camera is disassembled the capacitor will need to be removed. Ribbons are gently pulled away from connector.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kenneth
회원 가입일: 01/21/15
174 평판
안내서 1개 작성함
USF Tampa, Team 9-1, Brown Winter 2015 USF Tampa, Team 9-1, Brown Winter 2015 회원
USFT-BROWN-W15S9G1
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 18
전체 시간: 592
