주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W730 Control board Replacement
필요한 것
  1. Sony Cyber-shot DSC-W730 Control board Replacement, Removing the Case: 1 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W730 Control board Replacement, Removing the Case: 1 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W730 Control board Replacement, Removing the Case: 1 단계, 이미지 3개 중 3개
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 Control board Replacement: 2 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W730 Control board Replacement: 2 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W730 Control board Replacement: 2 단계, 이미지 3개 중 3개
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 Control board Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W730 Control board Replacement: 3 단계, 이미지 2개 중 2개
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 Control board Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W730 Control board Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 Control board Replacement: 5 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W730 Control board Replacement: 5 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W730 Control board Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 Control board Replacement, LCD Control Board: 6 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W730 Control board Replacement, LCD Control Board: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
결론
작성자
4다른 기여자 명과 함께
Douglas Howe
회원 가입일: 01/08/15
510 평판
안내서 4개를 작성함
USF Tampa, Team 9-4, Blackwell Winter 2015 USF Tampa, Team 9-4, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G4
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 788
