주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W730 LCD Screen Replacement
필요한 것
  1. Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: 1 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: 1 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: 1 단계, 이미지 3개 중 3개
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 LCD Screen Replacement: 2 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 2 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 LCD Screen Replacement: 5 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 5 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Control Board: 6 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Control Board: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
  7. Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Screen: 7 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Screen: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to remove the ribbon that is connected from the LCD screen to the camera by pulling the part that is folded under, out.
  8. Sony Cyber-shot DSC-W730 LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Slide the right side of the LCD screen clockwise, which will push it off the camera. The rest of the screen should come off with it with ease.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jeremy Petchonka
회원 가입일: 01/20/15
279 평판
안내서 2개를 작성함
USF Tampa, Team 9-4, Blackwell Winter 2015 USF Tampa, Team 9-4, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G4
3 회원들
안내서 12개를 작성함
2가이드 댓글
Excellent tutorial. It helped me a lot. I ve just replaced my LCD with success.
Thank you
joao - 답글
I can record with the camera but I can't see the image while taking photos. Any suggestions?
Robin_o - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 46
전체 시간: 1,909
