소개
The motherboard is one of the hardest components on the camera to replace. Be very careful when taking apart the ribbons, you could accidentally damage other parts of the camera.
필요한 것
Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
After the screen is off, work the spudger under three clips to remove the metal plate.
다른 한 분이 해당 안내서를 완성하였습니다.
