주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W730 Outer Case Replacement
필요한 것
  1. Sony Cyber-shot DSC-W730 Outer Case Replacement, Removing the Case: 1 단계, 이미지 1/3 Sony Cyber-shot DSC-W730 Outer Case Replacement, Removing the Case: 1 단계, 이미지 2/3 Sony Cyber-shot DSC-W730 Outer Case Replacement, Removing the Case: 1 단계, 이미지 3/3
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 Outer Case Replacement: 2 단계, 이미지 1/3 Sony Cyber-shot DSC-W730 Outer Case Replacement: 2 단계, 이미지 2/3 Sony Cyber-shot DSC-W730 Outer Case Replacement: 2 단계, 이미지 3/3
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 Outer Case Replacement: 3 단계, 이미지 1/2 Sony Cyber-shot DSC-W730 Outer Case Replacement: 3 단계, 이미지 2/2
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 Outer Case Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-W730 Outer Case Replacement: 4 단계, 이미지 2/2
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 Outer Case Replacement: 5 단계, 이미지 1/3 Sony Cyber-shot DSC-W730 Outer Case Replacement: 5 단계, 이미지 2/3 Sony Cyber-shot DSC-W730 Outer Case Replacement: 5 단계, 이미지 3/3
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jeremy Petchonka
회원 가입일: 01/20/15
279 평판
안내서 2개 작성하였습니다
USF Tampa, Team 9-4, Blackwell Winter 2015 USF Tampa, Team 9-4, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 742
