주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W800 Button Board Replacement
필요한 것
  1. Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: 1 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: 1 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: 1 단계, 이미지 3개 중 3개
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Button Board Replacement: 2 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W800 Button Board Replacement: 2 단계, 이미지 2개 중 2개
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Button Board Replacement: 3 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W800 Button Board Replacement: 3 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W800 Button Board Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Thomas Campo
회원 가입일: 02/09/16
851 평판
안내서 4개를 작성함
USF Tampa, Team 17-5, Blackwell Winter 2016 USF Tampa, Team 17-5, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G5
5 회원들
안내서 5개를 작성함
4가이드 댓글
Thanks for this - was spot on and allowed me to easily fix the problem I was experiencing!
jimbradshaw - 답글
follow the step camera button loosen a bit unstuck but camera still stock on language setting and do not budge
Trisha Amable Girlfridayz - 답글
follow the step the button are unstuck but the camera display still stock on language setting
i need a new strip, because old strip was damaged.
moonbhaai@gmail.com
Naveed Shoukat - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 50
전체 시간: 3,286
